Home audio help ASAP
I just want to make sure we are talking the same layout.
Can you confrim?
ONKYO HDMI INPUT 1 <-------- Cable Box HDMI OUTPUT
ONKYO HDMI INPUT 2 <-------- PS3 HDMI OUTPUT
ONKYO HDMI OUTPUT ------> TV HDMI INPUT
If that is the way you have it connected and you are having a problem, then it may be a HDMI version issue. How old is the TV or ONKYO? I dont remember if early HDMI had HDCP (High Definition Copy Protection) which your new ONKYO probably has and your TV might not or vica versa. Can you connect the PS3 to the TV via HDMI and does it work properly? Are there any HDMI settings in the ONKYO or TV? BTW, you can get by with comopenent (RGB) cable to connect for HD signal, but the BlueRay player in the PS3 may require HDMI to appease the MPAA (think RIAA for the movie industry).
