JL Audio 10" Sub for $110?
* Continuous Power Handling (Pt): 150 Watts RMS
* Nominal Impedance (Znom): Single 4 ohm
* 1-Way, Linear Excursion (Xmax): 0.375 inches / 9.5 mm
* Nominal Dia.: 10.0 inches / 250 mm
* Overall Dia.: 10.5 inches / 267 mm
* Mounting Depth: 4.34 inches / 110 mm
* Net Weight: 7.81 lbs. / 3.54 Kg
* Driver Displacement: 0.025 cu. ft. net / 0.71 liters
* Rec. Sealed Enclosure: 0.625 cu. ft. net / 17.7 liters
* Rec. Ported Enclosure: 1.00 cu. ft. net / 28.3 liters, tune to 31 Hz
would this be a decent sub for my camaro? im going to put it in a stealth box like this:
if it is decent, what amp would u go with for this?
sorry for the noobie questions, i dont know anything about car audio
