Rear window defrost
Old Jan 25, 2007 | 02:42 PM
67GoatPimp's Avatar
Default Rear window defrost
I have an 01 Formula, and for some reason when I turn it on, the light will stay solid for maybe 30-60 seconds. Then start flashing irradically. I doubt it's supposed to flash like that. If it wasn't so consistent I would assume it's a wiring issue, but I don't know where to even start. Anyone else run into this or have an idea as to what's going on?
Old Jan 25, 2007 | 03:43 PM
2001NBMZ28's Avatar
Next time it happens see if the power seat controls are erratic too - think they're on the same circuit. Maybe the circuit breaker is weak? If you suspect the breaker, temporarily replace it with a regular fuse of the same value and see if it stops. Just an idea...
Old Jan 26, 2007 | 01:44 AM
67GoatPimp's Avatar
It happens every time i use it It's 19* and my car is covered with ice. It sucks. I don't wanna drive the exploder.
Old Jan 26, 2007 | 07:36 AM
WhiteBird00's Avatar
Ungrounded Moderator
It's probably the circuit breaker - they get weak as they age. Replace it with an ordinary 30-amp fuse (it will plug right in) and the problem should go away.
Old Jan 26, 2007 | 07:58 AM
W105's Avatar
THREAD HIJACK lol
I dont even have a rear defrost haha...it's a 98 and originally i thought 98's must have not come with it, but after seeing two other 98's that did im confused. Any info on this?
Old Jan 26, 2007 | 08:13 AM
Originally Posted by W105
THREAD HIJACK lol
Check your door for the C49 option code. It's listed as optional equipment although most dealers automatically added it to all their orders.
Old Jan 26, 2007 | 08:29 AM
67GoatPimp's Avatar
Where is said circuit breaker?
Old Jan 26, 2007 | 08:34 AM
Look in the fuse panel on the left end of the dash. You'll see a silver box labeled DEFOG/SEATS plugged into the rightmost column. Pull it out and you'll see that it has a pair of spade (blade) connectors just like an ordinary ATO-type fuse.
Old Jan 27, 2007 | 03:14 PM
67GoatPimp's Avatar
I found it before I even saw the post, i was visualizing something more like a switch and the larger style fuse. I 've never had a car with circuit breakers in it, heh. It fixed the problem though. Thanks.
