Elemental Designs subs and ohm rating
Old Jan 25, 2007 | 05:15 PM
SmokeySS's Avatar
Default Elemental Designs subs and ohm rating
Looking into stealth enclosures and subs and had ED in mind. They have a couple 10 inch subs but they're available in dual 2ohm and dual 4ohm. What is the difference?
Old Jan 25, 2007 | 06:27 PM
fredmr39's Avatar
The difference is as they say - they each have two voice coils...but on one the VC's each have an impedance of 2 ohms; and on the other 4 ohms per voice coil.
You can obtain a nominal impedance of:
1 ohm (VCs in parallel) or 4 ohms (VCs in series) w/ the D2 model.
2 ohms (VCs in parallel) or 8 ohms (VCs in series) w/ the D4 model.
So, based on your amp/needs....choose the appropriate sub.
