Cruise control wires question
Old Feb 9, 2007 | 05:26 PM
Strahley's Avatar
Default Cruise control wires question
(Tried searching, but didn't find any answers)
I'm trying to find which wire(s) is/are used for the cruise control toggle. Basically, I removed the cruise control (during th350 swap) and was wanting to hook my trans brake switch up to the button you press to activate the cruise control. Anyone know which color wires in there are used to complete the circuit?
Thanks
Old Feb 9, 2007 | 07:56 PM
WhiteBird00's Avatar
Ungrounded Moderator
The three wires you're looking for are in the 11-pin flat connector at the base of the steering column (it's not attached to the column). They are grey, dark blue, and gray with black and they're between two pink wires in the connector. The gray wire has 12V+ when the slide switch is in the ON position. The dark blue wire has 12V+ when the set button on the end of the lever is pressed. The gray with black wire has 12V+ when the slide switch is pushed to the resume/accelerate position. These are all low current circuits so you might want to connect a relay if you use them to control an accessory.
Old Feb 10, 2007 | 02:43 PM
Strahley's Avatar
Great, I'll check there and experiment. Thanks!
Old Feb 11, 2007 | 03:48 PM
Strahley's Avatar
Having some troubles finding it. Does anyone have a picture diagram of which wires they are?
Also, I noticed that there are four little wires that lead from where you activate the cruise control. Could any of those wires be used to splice into, to grab a small hot lead?
Old Feb 12, 2007 | 07:20 AM
The wires you want are in the wiper/washer/cruise connector shown here:
Old Feb 12, 2007 | 11:05 AM
Strahley's Avatar
I kinda thought those were the ones, but I wasn't sure. Thanks for that diagram
