Which are the connections?
Old Feb 19, 2007 | 04:02 PM
Brian2006's Avatar
Default Which are the connections?
Could someone tell me which pins are power, positive, and ground on a 98-02 factory fog switch? I'm trying to power other accessories with 2 extra fog switches.
Old Feb 19, 2007 | 04:37 PM
XtinctZ28's Avatar
Rehab is for quitters...
https://ls1tech.com/forums/wiring-stereo-electronics/115434-fog-light-switch.html Post #2
https://ls1tech.com/forums/showthrea...g+Light+Switch
https://ls1tech.com/forums/showthrea...g+Light+Switch Post #6
Old Feb 19, 2007 | 09:24 PM
Brian2006's Avatar
Yeah unfortunately my switches didn't come with the harnesses. But, from using a 9volt battery, I've so far been able to figure out that pin 5 is negative and pin 3 is positive. Just need to keep trying combinations with the battery and led to figure out the power pin.
Old Feb 19, 2007 | 09:28 PM
tsench's Avatar
what is in ur mind now brian??
Old Feb 20, 2007 | 05:09 AM
XtinctZ28's Avatar
Thats why I gave you this info in the links above...
Originally Posted by Duffster
A B C
0 0 0
0 0
F E D
Pin A and Pin E are basically the on/off switch
Pin F will give you LED power. . .
