Monsoon Amp/Sub Install question
I have a question on an amp/sub install on a monsoon system in my 2001 T/A. I'm trying to install 3 10' subs (same box) with an 800W amp. the amp has power, and it's being triggered correctly. but I cannot get any audio. I am using a loc, and I've tried hooking it to the rear speakers after the amp, before the amp, and at the right rear sub after the amp, but I cannot get anything. I think it may be because the loc i'm using says 3-60 watts on it, but I'm not sure wether that's the issue or not. I may just wait and get a different HU and hook it up dirrectly to the HU and just do the re-wire (or harness).
Any help is greatly appreciated and thanks in advance.
Any other suggestions?
So, the problem isn't where you're getting your signal. We can also assume it's not the amp because you've tried others. That leaves a faulty LOC or incorrect/faulty wiring as the two possible causes of the problem. You can check the LOC by getting an RCA-to-mini adapter cable from Radio Shack for a few dollars and using it to plug a pair of headphones into the RCA output of the LOC. That should tell you if the problem is with the LOC and its wiring or with the amp and its wiring - in other words, are you getting a signal to the amp.
