shift light
Old Feb 27, 2007 | 05:12 PM
sampson01's Avatar
Default shift light
does anyone know about how we have the shift light on the cluster ... i was wondering if there was any way that you could tap off of that to make a redline shift light .... if any one knows any thing about that please leave something here or send me a message
thanks
SAMPSON
Old Feb 27, 2007 | 05:36 PM
6-Speed Terror's Avatar
i tried for a long time and called it quits never found out how it works just bought an aftermaket shift light and solved my problem
Old Feb 28, 2007 | 10:00 AM
WhiteBird00's Avatar
Ungrounded Moderator
I assume you're talking about the skip shift light on the dash of V8 M6 cars. It is controlled by the powertrain control module (PCM) which sends a class 2 serial data signal to the instrument cluster when the engine is at normal operating temperature, the transmission is in first gear, the vehicle speed is 12-19 mph, and the throttle is open less than 35%. The instrument cluster responds by turning on the indicator light and a solenoid on the transmission activates to lockout second and third gears - forcing a first-to-fourth shift.
Since the indicator lamp is electronically activated by a data signal rather than just a 12V power source, it would be difficult if not impossible to use it for another purpose.
Old Feb 28, 2007 | 05:15 PM
sampson01's Avatar
alright thanks .... what do i hav to tap into for a shift light those .... doesnt that shift on the cluster show up for all gears not just skip shift ???
Old Feb 28, 2007 | 05:35 PM
SweeTbone's Avatar
Are you talking about this?
http://www.hptuners.com/forum/showthread.php?t=3164
I guess in HP Tuners, there is some sort of "Shift Light" somewhere in there. But it's not feasible or there are some problems getting it to work. I would just stick to the aftermarket light tapped into the PCM.
Old Feb 28, 2007 | 06:02 PM
No, the light actually says "Skip Shift".
Old Feb 28, 2007 | 07:07 PM
sampson01's Avatar
alright thanks
