Easiest way to convert 12V to 5V
Old Mar 3, 2007 | 03:19 PM
Dom's Avatar
Dom
Default Easiest way to convert 12V to 5V
I need a constant 5V signal. I figure I'll just take a 12V from the battery and step it down. What's the easiest way to do that? Thanks in advance.
Old Mar 3, 2007 | 04:30 PM
dragonrage's Avatar
If you don't need a lot of current, just use a linreg like a 7805.
Old Mar 4, 2007 | 09:37 PM
ScrapMaker's Avatar
Depending on what you are using it for, you could simply use resistors... but again, it really matters what you are using it for... For example, you really don't need a constant 5v source for LEDs, so resistors would work fine... something like a microcontroller would definitely need regulators...
Old Mar 5, 2007 | 11:29 AM
dragonrage's Avatar
That is a good point. If just for LEDs or something that don't require an exact voltage, you can definitely do it with resistors.
