one door light is dimmer??
Old Mar 3, 2007 | 06:53 PM
presto_z's Avatar
Default one door light is dimmer??
well i just changed out the door lights with some blue #74 led bulbs and the passengers side is really dim compared to the drivers side...
they both are bright when out of the socket they twist into.. its like the clear plastic isnt projecting the one side as well as the other..
i already tried diffrent bulbs
any ideas
Old Mar 4, 2007 | 11:32 AM
presto_z's Avatar
i still have no clue why its doing this.. there is nothing obstructing the hole, and the bulb is super bright... has anybody else had this problem..
i cant belive something this easy is kickin my ***..
Old Mar 4, 2007 | 03:37 PM
shouldaboughttheZ's Avatar
I have the same problem.
Old Mar 4, 2007 | 04:15 PM
The Guz's Avatar
Same issue here.
Old Mar 4, 2007 | 05:12 PM
presto_z's Avatar
well atleast im not the only one..
Old Mar 4, 2007 | 09:33 PM
ScrapMaker's Avatar
What door lights are you referring to?
Old Mar 4, 2007 | 09:36 PM
Furious_George's Avatar
hmmm ya i was starting to wonder if i installed mine wrong, i'll probably just fabricate a better piece of plastic to go in the slot.
Old Mar 5, 2007 | 08:05 AM
ScrapMaker's Avatar
I honestly have no idea what these door lights are... Do you mean map lights? or the dome light? My t/a doesn't have anything else, besides this really dim red bulb, maybe 2mm wide, in the door just above the controls... it doesn't light anything up, and I figured it was some sort of indicator... my passenger side door doesn't even have it... is that what you guys are referring to?
Old Mar 5, 2007 | 02:37 PM
presto_z's Avatar
yes.. we are talking about the little lights above the controls...
my drivers side shines really bright.. even onto my leg, and the passengers side beam doesnt even reach the window controls
Old Mar 13, 2007 | 02:27 PM
vintageagain's Avatar
i've got the same problem, i'm going to take that part off and test it off of my car with the led hooked up to a power supply. Mine is super bright too but not projecting-it has to be something with the bezel.
Old Mar 13, 2007 | 03:01 PM
presto_z's Avatar
ya ive found this is very common and it seems nobody has come up with a solution
Old Mar 13, 2007 | 10:29 PM
ScrapMaker's Avatar
have y'all checked the voltage?
Old Mar 14, 2007 | 06:49 AM
That doesn't seem to be the problem. The led is bright as hell before you screw it into the bezel, just as the driver one. Once in the bezel the light isn't projecting. I noticed that the blue light was escaping where the coller the led is screwed into attaches to the back of the bezel. This could account for some of the light loss. i won't have a chance to look more into it until friday.
Old Mar 27, 2007 | 12:45 PM
02pewterZ's Avatar
Any new info on this? I am also having this same problem.
Old Mar 27, 2007 | 01:52 PM
It is a GM design flaw. I took it apart last night to look at it in more detail. The bulb shines directly into the back center of the bezel and then the light has to radiate to the top. The bulb connector is epoxied to the back of the bezel. I'm hoping this weekend i'll take off the bulb connector, see how GM decided to "route the light" and see if there is another way so we can use the plug and play bulbs. The easiest solution would be to use an led and resistor, cut the portion out of the back rear of the bezel and mount it there. Whatever way i go i'll take pics.
Old Mar 27, 2007 | 04:35 PM
02pewterZ's Avatar
Thanks.
Old Apr 10, 2007 | 11:44 AM
i didn't forget - I tried one method and got the light to be half as good as the drivers side. Not good enough for me so i'm trying another way.
Old Apr 10, 2007 | 02:38 PM
2KThunder's Avatar
Dude ive got the same exact issue. Never figured it out.
Old Apr 10, 2007 | 03:12 PM
presto_z's Avatar
if u figure anything out be sure to let us know...
goodluck
