please help my window!!!
Old Mar 12, 2007 | 07:30 PM
KILLER-LS1's Avatar
Default please help my window!!!
hey guys, my driver window is NOT working at all. at first it was intermittent but now it stopped all together. i have a new switch AND a new motor. the passenger side works fine... there is NO noise coming from the driver motor at all. i pulled out the power window control module (under the dash) and when i hit "down" the module clicked... (is that normal?) any ideas??
thanks!
Old Mar 12, 2007 | 09:19 PM
Gun5's Avatar
thanks!
mine does that if i hold the botton then it does the LETS get stuck half way ****.. (new motor, new switch here to) check ur ground but usualy that doesnt do anything either...
Old Mar 13, 2007 | 11:53 PM
letsrun97z's Avatar
try changing the relay worked good again untill the motor went out on the pass side
