HELP (electricity problem)
Old Mar 15, 2007 | 02:48 PM
alw041's Avatar
Default HELP (electricity problem)
My car has been running fine. Only thing i know i need to change is my BCM b/c of my radio/power windows intermittently shutting off.
So here is what happened:
Car was working fine this morning...
I go to start it, it cranks up like normal, then stays on for about 1 second then my car shuts off along with all the electronics. There is absolutely no electricity coming into my car. No lights will come one, nothing power works, alarm won't work right, putting key in won't make the beeping sound, nothing inside the car itself will work. The battery is good and all checked the fuses in the engine compartment. Except i don't know how to check those big square ones.
Anyone have any idea what happened to my car?
Old Mar 15, 2007 | 04:05 PM
alw041's Avatar
problem solved...
Old Mar 15, 2007 | 07:58 PM
WhiteBird00's Avatar
Ungrounded Moderator
Originally Posted by alw041
problem solved...
Don't leave us in suspense...what was it? (I'm guessing that if the battery was good then it was one of the battery connectors.)
Old Mar 19, 2007 | 10:16 PM
Gonad's Avatar
yes yes do tell!!
Old Mar 20, 2007 | 10:24 AM
alw041's Avatar
Yup, good guess.
It was actually the acc. battery terminal that is right next to the fuse boxes. It was not getting a good connection. I undid the bolt a couple of times and tightened it down and fixed everything after a couple of trails.
What confused me was that i never even messed with that connection area and it went bad randomly.
Old Jul 1, 2007 | 09:25 AM
Michael02hawk's Avatar
Thank you for posting the fix!
I had the same problem over the past week.
