Recommend me some Speakers
i dunno if you're refering to my post, but i run an aftermarket Amp and Headunit. so the ohms should be different.
<---OP
Still trying to find an inexpensive set of component speakers. The Infinities have been labeled as "bright", which isn't really what I'm looking for. Would settling for the SPS-170A's really make that much of a difference?
I am the farthest thing from an audiophile but I do know acoustics seeing as how I am an acoustics engineer. If you want very clear highs and good mid range then the Kappa is the way to go for the price. I got all of mine on eBay for $100 or less each after shipping. If you want to custom mount the rear hatch speakers just drill a few holes under the speaker covers and you will never see them, or just remove the speakers from the equation, it’s up to you.
I went with the Kappa’s because I had fully planned to go 4ohm in the entire car via two four channel amps and then installing a 10” sub in the stealth box. I had a completely Infinity system in my last car, which was not an F-body, and had people in the car audio business comment on how clean the sound was. That is what I was going for in my WS6. Loud is only good if you can hear the words.
There are infinite combos out there for subs, speakers, amps and opinions so what you need to do is research SNR, frequency response and if you can get your hands on output curves for the speakers. With that you can always see what speakers generate the best response to the frequencies you want to highlight. Just keep in mind that the Monsoon system needs to be nuked if you truly want good car audio.
and a set of Kenwood KFC X1700's for the rear.
I've got a friend selling me a 10" stealth sub, so all I'd need after that would be a sub.
How's that sound?
I also don't want to fill up my t-top location, or any other storage area. The stealth box fits where nothing else goes, so I might as well use it.
Just wondering if anyone had any input on those Kenwood and Alpine component speakers I mentioned in my previous post. I just bought them.
What amp will you run to get the sub going? Don't get something too powerful of you will saturate the lower frequencies.
