My Audio Set up!
Old Apr 8, 2007 | 03:19 AM
Silver UltraZ's Avatar
If I bridlge the 200 watt amp at 4ohms they push 200w... And I like symetrical... Its fun
Old Apr 8, 2007 | 08:39 AM
2MuchRiceMakesMeSick's Avatar
at first glance, i though that was peel-n-seal, im glad its not.
Old Apr 8, 2007 | 11:10 PM
02Z28LS1's Avatar
but that's only into one channel, not two....am i missing something here?
from the info i have gathered on those amps, they are only 2-channel amps with the following specs:
RMS Power @ 4 Ohms: 50W x 2
Bridged RMS Power @ 4 Ohms: 200W x 1
so you would either need two 4-channel amps bridged into two channels each, or four 2-channel amps bridged into one channel each, in order to power all 4 of the front/rear speakers at the 200w you're talking about pushing to them
maybe a wiring diagram would help me visualize the way you will be setting it up, because as of right now, it's hard for me to figure out a way that the equipment you have will result in your goal.
