factory monsoon
Old Apr 8, 2007 | 04:26 PM
styoung's Avatar
Default factory monsoon
my factory monsoon radio in my 2002 z28 cuts out when i hit a bump. now it dosent do it every bump only the bigger ones. when it happened the first few times i thought it was the cd but it seemes to be doing it more and more. does anyone have any idea what it could be. thanks
Old Apr 8, 2007 | 04:47 PM
fredmr39's Avatar
-more than likely a loose BCM connection and/or faulty BCM.... When the radio shuts off, try moving your power windows next time to further confirm this....it actually doesn't seem as obvious that it's the BCM in your case as in others since it sounds like every time it cuts out it comes back right away (by the way you described it).
Try moving your windows when it happens again - and if they move, look elsewhere for a short behind the radio, etc. - otherwise check all power/ground wires to/from the BCM.
Before replacing the BCM, do what you can to be sure there isn't just something shorting out somewhere.
Old Apr 8, 2007 | 04:57 PM
styoung's Avatar
well the radio still get power because the clock still has power, but the sound cuts out and i turn it off and back on and its fine.
Old Apr 8, 2007 | 05:00 PM
fredmr39's Avatar
Maybe a loose power/ground/etc. at the Monsoon amp?
Old Apr 8, 2007 | 05:23 PM
styoung's Avatar
i will check that out, where is the amp located?
Old Apr 8, 2007 | 06:00 PM
VIP1's Avatar
Copy & Paste Moderator
Remove the passenger-side rear panel (where the spare tire is located). You'll see the back of the amp on a bracket near the top of the tire well hump facing the quarter panel.
