yet another 6.5 sub thread
Old Apr 11, 2007 | 08:18 PM
tasilver's Avatar
Default yet another 6.5 sub thread
I know there are other threads out there on this just did not want to hijack. I replaced one of my sail subs in oct. Now the other is starting to crap out. I would like to replace them with something a little nicer that will run off of the factory amp. I also would like a direct fit. Any suggestions.
Also I know I will only use two of the wires to sub and not the four that it uses now. Just wondering which ones to connect. thanks for any help.
Old Apr 11, 2007 | 10:08 PM
JR HAWK 9's Avatar
After having a pair of Kenwood midbass, Peerless midbass, Elemental Designs 7Kv.2 midbass and the current CDT Audio M6's I can say that the M6's destroy the others I have tried. They are a bit more pricey, but they sound quite a bit better than the others I have mentioned.
Just connect either one of the two (+) and (-) on each side to the single voice coil.
Thanks to WhireBird00, here's the sail panel wiring:
Left side:
Tan +, White -
Dark blue with white +, Light green with black -
Right side:
Red +, Tan -
Dark green +, Light blue with black -
Old Apr 12, 2007 | 03:18 AM
fredmr39's Avatar
JR HAWK 9 - have you tried them using just one set of wires per side on a SVC midbass (if I remember correctly, you have these amped)?? I can't imagine that being better than using both pairs/channels of the amp on the DVC eu700s..
Old Apr 12, 2007 | 08:26 AM
JR HAWK 9's Avatar
no, I went from an all stock system to an all aftermarket system, so I never had anything hooked up to the factory speaker wires except for the factory speakers. Yeah, I don't know how they would sound just using one pair of the stock wires wired to a SVC driver, but I can tell you the difference between the 7Kv.2's and M6's in my setup was IMMENSE.
Old Apr 12, 2007 | 09:09 AM
tasilver's Avatar
So it does not matter which of the two sets of + and - I use just make sure I keep the sets together and do not splice all the + on one side together and all of the - together on the other. I will check into the speakers you have suggested. thanks for the help. I just dont understand about ohms and stuff but I am tring to learn.
