Weak bass. Help!
Old Apr 12, 2007 | 07:26 AM
97MysticZ's Avatar
What's a Sticky?
Default Weak bass. Help!
Okay, I just installed a brand new Alpine cd player in my car and I'm also installing a JL Audio 10" W3 (Dual 4 Ohm Voice Coil) in a stealth box with an MTX 421-D amp. I got the stereo all installed and the amp wired up and just wanted to test and make sure everything is okay. The sub works, but the bass is just....weak. The max wattage this sub is supposed to handle is like 300 watts RMS. The amp I have is supposed to put out 300 watts RMS at 2 ohms, but it was rebuilt right before I bought it and the test sheet says it actually put out 345 watts RMS @ 2 ohms. Something can't be right because when I sit in the front seat, I cant even hear the sub over the sail panel speakers.
I'm sure these factors don't help, but how much are they contributing to my problem:
1-The sub isn't actually in the box yet
2-I'm using some regular speaker wire to test it right now
---Would these 2 factors be enough to kill the performance? (It will be hooked up right later today)
I know the thing is wired right because I checked it MANY times. By the way I have the Dual Voice Coils wired in parallel to create a 2 ohm load.
Anybody have any ideas? Is there any way to test and see how much wattage the amp is putting out?
Old Apr 12, 2007 | 08:15 AM
XtinctZ28's Avatar
Rehab is for quitters...
I would think the sub not being in the box is having a substantial effect on your volume/loudness. Try it again with the sub mounted and see what difference it makes.
Old Apr 12, 2007 | 09:37 AM
MikeFbody's Avatar
Restricted User
yes, there is a reason subs need to be in boxes.. Just sitting free-air, they will make very little bass if any at all.
Old Apr 14, 2007 | 10:56 PM
USAF WS6 T/A's Avatar
Default Subs must be in box
Yes, the subs need to be in an enclosure in order to have the full effect of the subs... Unless they are free air speakers but even then free air speakers do not provide the sound pressure levels as an enclosed system. If you still are not getting the sound you need, then you need to check the amp and speakers... Additionally, make sure the speaker is ired correctly and the amp is getting the proper amount of voltage to keep up with the needs of the amp and speakers... I hope this helps...
Old Apr 15, 2007 | 12:09 AM
letsrun97z's Avatar
for sure no sub in box and prolly the hatch was open? =no bass and isnt that bad for the speaker?
Old Apr 15, 2007 | 05:09 PM
MikeFbody's Avatar
Restricted User
even free air speakers will not sound right playing in the open like that, free air subs still need to be in a baffle that vents to the outside or into a trunk. And yes, depending on the sub and the power delivered, you can damage a sub playing in the open like that.
Old Apr 17, 2007 | 11:53 PM
LT1wannabe's Avatar
sub minus box = male minus c***
