Dome light wiring question, please help.
Black is obviously the ground, blue/white is always hot, and white is hot when the dome is OFF. Is there a wire somewhere else that is hot when the dome is on, or am I missing something. wtf??? Any ideas will help, thanks.
You'll have to wire your CCFLs for power from the dark blue with white wire and ground through the white wire - there isn't any power wire you can use that is only on when the courtesy lights are on.
