brake lights wont work
any info will help
any info will helpYou can test at the turn signal switch connector. It is a black 11-pin single-row connector attached to the right side of the column under the dash. It has the following wire colors in the order listed: empty, black, light green, black, light blue with white, dark blue with white, brown, purple, yellow, dark green, and light blue. The light blue wire at the end is the brake light power input from the brake switch and the dark green and the yellow wires next to it are the output wires to the tail lights. Test with a multimeter or test light that you have power to the light blue wire when the brake pedal is pressed. If not then the wire is probably broken somewhere. Otherwise, check that you have power at both the yellow and dark green wires when the brake is pressed. If not then the turn signal switch is the problem. Otherwise, there is a problem with the wires from the switch to the tail lights (unlikely since both sides are involved).
thanks. I really appreciate it. this prblem wasnt serious but it was buggin hell out of me.
