monsoon cd player wont turn on
if it lights up, then fades away, it could be a few things. it shouldn't be any fuses, but double check them just in case. check the wires as you said, but also check and clean the wire harness connections.
if it was working when you took it off, it should still work unless it ran into brute force like a fall you weren't aware of.
