best speaker wire?
Old Apr 18, 2007 | 11:07 PM
DirtyBird222's Avatar
Default best speaker wire?
What is the best speaker wire to use with component speakers? replacing the stock monsoon system and wiring. Gettin a in-dash dvd head unit ect..
Old Apr 18, 2007 | 11:11 PM
95bat's Avatar
It's all the same. Get whatever will flow the current load you need.
I like buying from www.knukonceptz.com for my wire and RCAs. The name sounds a little shady, but their stuff is top quality and they have awesome prices.
Old Apr 19, 2007 | 07:06 AM
WhiteBird00's Avatar
Ungrounded Moderator
The best kind is made from conductive metal (like copper) and has insulation to keep it from shorting out.
As 95bat says, it's basically all the same - just make sure it's stranded (not solid) and get large enough gauge to handle the power you're using.
Old Apr 19, 2007 | 09:28 AM
95bat's Avatar
You idiot! If you knew what you were really doing you'd get the wood wire like the pros use!
Old Apr 19, 2007 | 09:34 AM
2MuchRiceMakesMeSick's Avatar
alot of the cheaper wire will oxidize as soon as 6 months
Old Apr 19, 2007 | 10:59 AM
VIP1's Avatar
Copy & Paste Moderator
Make sure you get Oxygen-Free braided copper wire.
That will reduce (or possibly eliminate) the risk of oxidation.
Also, make sure you get the right gauge for the load.
