How to disconnect auto headlight sensor????
Old Apr 29, 2007 | 01:38 PM
jond99's Avatar
Default How to disconnect auto headlight sensor????
I see the sensor in my defroster right next to my alarm led. But how do you get to it? I know i need to connect the two wires that go into the sensor and all but how do i reach the sensor without breaking anyhting. Thanks guys.
Old Apr 29, 2007 | 03:59 PM
WhiteBird00's Avatar
Ungrounded Moderator
It's really easy. You need to lift up the upper dash panel. In order to do that you have to remove the two A pillar trim pieces (next to the windshield). If you have t-tops, remove them and then take out the two screws at the top of the trim panel, then they just pull off. If you don't have t-tops then the trim panels just snap off. Once you've removed the trim, the dash panel just lifts up. It's held in place by a combination of snaps and velcro fasteners. Be very careful - the edges are sharp! (don't ask me how I know that )
Once you've lifted up the dash panel you don't even have to remove the sensor. Just use a scotchlock crimp-on connector over the two sensor wires to connect them together.
Old Apr 29, 2007 | 05:39 PM
jond99's Avatar
thanks dude.
Old Apr 29, 2007 | 07:22 PM
Silver UltraZ's Avatar
https://ls1tech.com/forums/showpost....21&postcount=6
