help with changing 1speaker
Old May 6, 2007 | 01:07 PM
fccs's Avatar
Default help with changing 1speaker
Ok I have a blown out speaker in the middle drivers side the one by the backseat well yea is there a easy way to change this??? lol
Old May 6, 2007 | 01:10 PM
WhiteBird00's Avatar
Ungrounded Moderator
You mean easier than pulling the panel, removing a couple of screws, and plugging in the new speaker?
Old May 6, 2007 | 01:11 PM
fccs's Avatar
well how do i take out the panel lol to me it looks like a fricken 3hr job I have the monsoon system if that matters and idk how to take it out how do i take the pannel of like the wall off to get to the speaker
Old May 6, 2007 | 01:15 PM
fccs's Avatar
if anyone has like a tutorial with pictures it would help alot i just cant figure out how to change the 1speaker right next to the rear drivers side seat
Old May 6, 2007 | 02:38 PM
fredmr39's Avatar
To pull the grille cover off....well that's it -- literally just pull it off. Just kinda use common sense to manipulate the tabs so that you don't break one. This should take 5 seconds per side using hands only -- do not try to pry there with a tool -- you will just scrape up the plastic.
Old May 6, 2007 | 05:34 PM
fccs's Avatar
yea i got it lol i thought you had to take off the whole panel and take out the seat haha
Old May 6, 2007 | 05:41 PM
fredmr39's Avatar
Yes, unlike the fronts, the grille only needs to be removed...you cannot just pop the grille off on fronts (door must come apart) -- you will crack it and you can't get the speaker out through the small space -- just fyi in case you try just removing the grille for the fronts as well.
