Battery Terminal Heating Up
Old May 23, 2007 | 07:00 AM
BirdofPreyBandit's Avatar
Default Battery Terminal Heating Up
OK, this is not an LSx vehicle but maybe someone can help. My wife's Mercury Villager minivan didn't want to start about a month ago. I found a lot of corrosion on the battery terminals. After a good cleaning, it worked fine until yesterday. I checked the battery again and there was a large amount of corrosion again!
I bought a brand new battery last night and it worked just fine until just now. It's doing the same thing again. The lights are flickering inside the van and it won't start. I opened the hood to make sure the battery cables were on tight and the positive terminal was very hot! The negative is fine.
ANY IDEAS? I need this fixed ASAP. The wife is going to have to drive the bird to work right now and that scares the hell out of me!
Old May 23, 2007 | 10:52 AM
VIP1's Avatar
Copy & Paste Moderator
If its hot, there is a short or loose connection.
Check that battery connection for damage/corrosion/loose.
Old May 29, 2007 | 12:56 PM
VIP1's Avatar
Did you get this resolved?
Old May 29, 2007 | 01:18 PM
ultraz's Avatar
use baking soda in a diluted solution with water to take off the corrosion. Clean off all the area in and around the battery terminal. IF i were you, id buy new cables, terminals , and a battery. It sounds like your battery is starting to leak.
Old May 29, 2007 | 02:48 PM
dragonrage's Avatar
Replace battery wires.
Old Jun 8, 2007 | 09:53 AM
Sorry I haven't replied. Yes, I got the issue resolved. I had the starter taken off and tested but it turned out to be a simple loose connection on the alternator. I never looked at the obvious, simple solutions! Damn it!
