Fuse question???
Old Jun 7, 2007 | 12:25 PM
TN94Z's Avatar
Default Fuse question???
I am running a main power wire from my battery to a distribution block under the dash. I will be using the distribution block to run my dual stage nitrous, trans brake, raptor shift light, line lock, purge, temp gauge...basically anything that I will be powering from now on. My question is, what size fuse do I need to use in the main line? I have an in line fuse holder that will take a 30amp max fuse lying around. Thanks
Old Jun 7, 2007 | 12:58 PM
MikeFbody's Avatar
Restricted User
it depends on the size of the wire.
Old Jun 7, 2007 | 02:19 PM
TN94Z's Avatar
8ga. wire
Old Jun 7, 2007 | 03:41 PM
MikeFbody's Avatar
Restricted User
a 30 amp fuse will do fine then.
Old Jun 9, 2007 | 01:45 PM
TN94Z's Avatar
One more question. If I run the main line from the battery to my distribution block what will keep everything from running the battery down? That will give everything power constantly. Do I need to go ahead and install a battery disconnect or just put some other kind of switch in line? This is on a race car by the way.
