Adjusting an amp with an oscilloscope
To be more specific, it's a function of measuring V/t.So you are actually looking at the voltage output at a specific time junction. 2K hz is 0.0005 sec. (1/Freq) Or the range would be .5 ms or 500 microsec.
Then you'd look at the shape of the wave form like 95bat said. Google "Sine Wave" and memorize the shape. That's what you want to see. It won't be absolutely perfect. No man-made electronic wave form is perfect nor is it perfect in nature. There will be minor deviations from a true line/curve. Tiny spikes along the curve is fine so long as the shape is generally smooth and uniform. Don't get too hung up on the shape if it looks like a normal sine-wave curve overall.
The scope doesn't measure power, just voltage. To get the power you'd have to view the peak voltage and the amprage. Then convert to watts. rms and avg are derived from the peak. ( 1.414 x Vrms= Peak Volts AC and avg being Vavg= .637 x Peak Volts AC) The amplifier works by either voltage gain or amperage gain to achieve a certain Watt output. You may have to use a high-voltage probe to measure some amp's output.
If you are using a Scope to set-up your amps all you are really looking to do is to set the gains so they don't clip. You start with the HU and measure where it starts to clip. (What volume setting). Then you move down stream and set each device up to the point where it won't clip. You are basically establishing your high baseline value.
After this is done, you can go downwards, but going upward will clip the signal depending on the music. It is possible to play your music louder then the measured clip since we all have different values of clipping that we don't hear. BUT, clipping is harder on the speakers and the electronics since a clip is a HIGH DC signal. It would be like moving very fast and then Dead stopping. Momentum and force is great here and can rip a speaker aprt literally.
