How To Program New Key FOB?
Old May 9, 2003 | 03:22 PM
Dave00C5's Avatar
Default How To Program New Key FOB?
I have a new replacement key fob in need to program to the car. Its a 99 Trans Am, can I do this at home or a visit to the dealer is needed? Thanks in Advance
Old May 9, 2003 | 05:17 PM
Str8crusinT/A's Avatar
From: Oklahoma 1000+ posts from LS1.COM and 430+ posts from WWW.COFBA.COM
Default Re: How To Program New Key FOB?
go to www.installuniversity.com and look and the installs section and it will have it there
Old May 9, 2003 | 07:10 PM
Steve1969LS1's Avatar
This really belongs in electronics to get a good response
Then again the key fobs are pretty good looking
Old May 22, 2003 | 01:14 PM
Nightfall's Avatar
Got this from someone here.....
Transmitter Programming
All transmitters which are to be recognized by the body control module (BCM) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
Turn the ignition switch to the OFF position.
Remove the RADIO (#17) fuse.
Cycle the ignition switch from the OFF position to the RUN position 3 times within 5 seconds. The BCM will confirm entry into the programming mode by performing the following actions:
Locking both of the doors.
Unlocking the driver's door.
Releasing the rear compartment lid.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter for approximately 15 seconds. The BCM will confirm the programming of that transmitter by performing the following actions:
Repeat the previous step to program up to 4transmitters.
Replace the RADIO (#17) fuse.
Operate the transmitter functions in order to verify correct system operation.
