Stock sub harness...
Old Jul 10, 2007 | 10:04 AM
its turbo time's Avatar
Default Stock sub harness...
WHere can i get the four wire harness that plugs into the stock sub location speakers? The original guy that had my car put kicker ks60's powered by the sail speakers and i would rather power them with the wattage that went to the stock "subs." but the harness is missing...all i have is the four wires w/o a harness on one side and the female connector with the wires plugged in on the other side.
thanks
Old Jul 10, 2007 | 10:14 AM
WhiteBird00's Avatar
Ungrounded Moderator
I assume you mean that the previous owner had the Kicker speakers mounted in the sail panels and had pulled the hatch speaker wiring forward to run them. There is a good reason for that and you shouldn't change it. The factory subs get a low pass filtered signal from the amp so you can't run your coaxial Kickers off that signal (well, you can...but you'll get nothing but weak bass from them). The hatch speakers get full-range signal so using those wires provides better sound when replacing the factory subs with coaxial speakers.
Old Jul 10, 2007 | 11:32 AM
other way around kickers in the hatch
Old Jul 10, 2007 | 12:00 PM
Okay...regardless of where they're mounted, you can't power the coaxial Kickers from the factory sub wiring unless you want to get nothing but bass from them.
Old Jul 10, 2007 | 03:47 PM
yeah, i've got a kicker cvr 10 sub powered by an xtant 121m, you think i should just leave it be? Or is there something better i could put in the hatch then move the kickers to the sails? What would you do?
