01 suburban elec. problem
Old Jul 14, 2007 | 06:02 PM
diggla's Avatar
Default 01 suburban elec. problem
Have a 01 suburban, the drivers headlight is dim while the passenger one shine regular. There are no splices on the headlights, I changed the bulb with the correct one and even swapped sides and it still has the same problem. Does anyone have any ideas????????????????????????????????????????????? ???
Old Jul 14, 2007 | 10:33 PM
I-10 b4c runner's Avatar
check the ground on the drivers side headlight and make sure there is no corrosion in the harness
Old Jul 18, 2007 | 03:28 PM
diggla's Avatar
I checked all the grounds to the addons, tried wiggling the wires to the connector and still no love. On both headlights there is a orange and a yellow wire. Which is which. I figure if i can tell witch one is the groun i'll ground it myself and see if that helps. If not does anyone have a diagram of the electrical so i can follow the lines and see where is grounds to.
__________________
