Sub woofer/Amp wiring help
Old Jul 19, 2007 | 11:16 PM
pentavolvo's Avatar
the amp is 1 ohm stable, get a hold of an infinity rep and ask him 611 and 1211 are both 1 ohm stable not advertised and no increase in power we did it at work all the time never an issue, just like the jbls which advertise it, both made by same company
Old Jul 20, 2007 | 02:40 AM
Richiec77's Avatar
Is it the same parts inside the amp? If so, then it could handle the resistance. But really. The true difference that you can hear between 850 and 1500 is not as great as everyone thinks. It's not a doubly effect to your ears.
Also, I hope I'm not digging to deep for the original poster, but the impedance curve for the subs in an enclosure over the freq spread will change. It may go lower then 4 ohms and higher for sure. I will never warranty nor really recommend wiring up an amp in 1 ohm if it's rated for 2 ohms, but I'm pretty sure the amp can handle since it won't really be playing in the 1 ohm area for sure. But you just never know unless you actually measure the impedance using a singal generator and ohm meter. It all has to do with Zo for the final amp stage. (engineer will recognize what Zo is)
If the output resistance is too light, you risk over saturating the circuit and that will burn out the components in line. Basically breaking the amp.
If you want to learn even more....But it's advanced info in this link. Might be over alot of peoples heads here unless they've done some electronic class in college or maybe high school even!?
http://focus.ti.com/lit/an/sloa011/sloa011.pdf
Old Jul 20, 2007 | 11:17 AM
95bat's Avatar
I wouldn't take the risk of running it at 1 ohm, especially if you have the stock electrical system. Amps at 1 ohm need the alternator/battery power to back them up. If you don't have that, I don't care what amp you're using, you'll be fixing it shortly.
Just wire it up at 4 ohm like we've suggested. You don't even need more power than the amp makes at 4 ohm, so there is no worry about getting a lower impedance to get more power from the amp.
Old Jul 20, 2007 | 07:27 PM
BrentHamm's Avatar
ITs already done...4 ohm. Subs sound GREAT. Have to finish the rest of speakers yet..
