Factory alarm beeping ???
Old Jul 22, 2007 | 01:39 PM
crzytown69's Avatar
Default Factory alarm beeping ???
everytime i lock it the alarm goes off ten seconds later. what the hell...it beeps twice then stops...ten senconds goes bye and it does it agian i just unpluged the shock sensor in the back where the spare is and it stoped. with the shock sensor plugged up its beeps twice every 10 seconds... any one else having this issue
Old Jul 22, 2007 | 02:55 PM
2001NBMZ28's Avatar
Alarm going off just after arming is usually the shock sensor - think you found the problem. You can also try turning the sensitivity down.
Old Jul 22, 2007 | 09:16 PM
crzytown69's Avatar
ill try that ... the shock sensor is built in our harness too isnt it
Old Jul 23, 2007 | 06:55 PM
nhra_crazy's Avatar
ya mine is doing the same thing also. I lock it then it beeps twice about 20sec later then stops
Old Jul 23, 2007 | 07:42 PM
shouldaboughttheZ's Avatar
the sensor is above the back passenger wheel. You will have to remove the plastic panel. It is a little black box with a red led on it. It just unplugs from the harness.
Old Jul 26, 2007 | 03:30 PM
nhra_crazy's Avatar
Will the alarm still go off with that sensor unplugged?? Cause this thing is getting really annoying!!
Old Apr 9, 2009 | 08:51 PM
67camaro's Avatar
Default Up from the dead
I would like to know this too. I think I have this problem.
Old Apr 10, 2009 | 08:26 AM
WhiteBird00's Avatar
Ungrounded Moderator
You couldn't find a more recent thread on this subject?
The alarm will work normally without the shock sensor - except it won't respond to impacts of course.
Old May 7, 2009 | 08:35 PM
67camaro's Avatar
Whats wrong with bringing back an old thread? If old threads are useless then why doesnt ls1tech staff delete them?
Thanks for the info.
Old May 8, 2009 | 09:06 AM
In this case, the same subject has been discussed dozens (perhaps hundreds) of times in the two years since this thread was started. Granted, not much has changed regarding the alarm system but lots has changed in other subjects (especially audio) so it's always best to use the most current information.
