Weird problem with the factory monsoon system*read faq*
So first thing I figure... Loose wire somewhere... I rip out the factory radio, check all around... push the pins farther in the connectors... put it back on the radio, still nothing...
So I took off the rear fender panel and did the same thing to the connectors going into the subs, and messed with the entire clip going into the amplifier....
Well I tried a few more scenarios to try to narrow it down more on to what the problem could be. I found something odd... If the car is completely off and I slam the rear hatch closed, and turn the car on. I get no subs what-so-ever. However if the Radio is on! when I slam the rear hatch closed. Poof magically works, so it def. has to be some form of lose wire or something. Is there an inline fuse somewhere that might also be messing with it? I figure since abrupt motions in the rear is what fixes it that the problem area must be somewhere in the rear which is where the amp is...
anyone got any input?
thanks in advance
p.s. this is a 100% OEM equiped stereo
