Volume instantly cutting down. HELP!
Old Jul 26, 2007 | 08:30 PM
2001BlkWS6's Avatar
Default Volume instantly cutting down. HELP!
Driving down the road with the radio decently loud my music hits a part where it has alot of bass and then all of a sudden the volume completely cuts off and i have to turn it down then back up to get any volume again.
Anyone have any idea what this might be and what the fix for it is? Thanks.
Old Jul 26, 2007 | 09:05 PM
Richiec77's Avatar
What is your set-up? Stock or aftermarket?
What that sounds like is undercurrent/undervoltage protection. Basically when the bass hits hard, it draws alot of current to the point the voltage drops down to about 10v or less. It throws the amp into protection since wattage is IV Current x Voltage. If you drop the voltage, the current must go up to keep up with the dB demand of the amp. Too much current will kill a piece of electronics.
Old Jul 26, 2007 | 10:01 PM
2001BlkWS6's Avatar
Its all stock.. Could you put that into lamens terms and what I can do to fix it? lol
Ive had it alot louder before and it hasnt done this.
Old Jul 28, 2007 | 10:11 PM
LT4hotcam's Avatar
Mine had the same problem but when i would just be driving it would turn up to the max all by itself , now it turns down all the way.
Old Jul 28, 2007 | 10:46 PM
ultraz's Avatar
your cd player= trash, more than likley, unless u wanna try to take apart the circuit board and try to find the problem. This happens with aftermarket units as well.
