Help Hurry!! My Lights Dont Work!!
No Gauges or console lights on, No Taillights on No head and Daytime running lights on too.
But when I push hazard it or push the break lamps works..
When I fully turn on the switch. at High Beam lights FOG LIGHT AND HIGH BEAM works.. (usually when you turn High beam fog lights is turn off) at low beam fog lights turn off..
Any ideas why that could be happen??
95 TransAM
BTW Transams have 2 fuse box?
1 is at the drivers doors other is atunder the hood?
I had checked it and
The first thing to check is the TAIL LPS fuse. Don't just look at it - test it or replace it with a known good fuse because fuses often look fine even when they're blown. The TAIL LPS fuse protects all of the exterior running lights (front and back) as well as the instrument panel lights.
He said did anyone pull out something.. I said Yes my rear bumper for paint..
He checked and noticed that a electiric cable has jammed becuz of bumper when it has attached.. He pull the cable did something,and thats ok!
nice isnt it..
Thanks for your answer anyway!
