System shuts off and then back on
Sounds like a loose wire. First you have to determine if both amps are doing it or just one. Try pulling the fuse out of the bass amp for a while and see if it happens. Then I would move on to the remote turn on wires. Then move on to the grounds for the amp. Then make sure that the speaker wire isnt shorting out to ground. What kind of amps are they?
