write up for a sub box?
Old Aug 11, 2007 | 12:54 AM
JoeKnowsBaseball's Avatar
Default write up for a sub box?
i built one for two 15"s in my old camaro and then it got stolen. lol it was the type that takes up all the truck space except the shelf. i want to build one that fits in the cubby hole tho. similar to the JL audio or stealthbox.
i was wondering if anyone had a write up on how to build a box. obviously it doesn't matter what size sub (10 or 12) cause i can just cut the whole bigger/smaller. i can do all the measurements, but i wanna cut down on some of the time if i can just cut and paste.
thanx for the help in advance.
Old Aug 11, 2007 | 09:26 AM
KEE AUDIO's Avatar
Actually, a stealth box is generally about .6cu.ft. of airspace so a 12" sub would require more. That's why they are all 10" sub for the most part. However since you are building your own you could extend it up into the area behind the side panel to give it more airspace volume to accomodate a 12" sub. Here's a link that may help you:
http://www.fbodyaudio.com/articlevie...tealthbox.tech
Granted this is for a passenger side enclosure but you get the general idea from this. Hope this helped!!
Old Aug 11, 2007 | 05:41 PM
thanx dude. that's a really nice write up. i'll see if i can convince my dad to help since he used to do a little fiberglass.
anyone got a write up for a wood box?
