Help me find an amp!
Old Aug 11, 2007 | 10:47 PM
porksoda's Avatar
Default Help me find an amp!
I need suggestions on what amp I should look into for some subs my brother just bought for his truck. The subs are 2 12" JL Audio W3V2 D2's. What kind of amp do I need to push these subs, NOT blow them? My budget is around $300. I really don't want to spend more than that. I've been looking at the JL Audio 500/1 monoblock amp but a little cheaper wouldn't hurt either.
Old Aug 12, 2007 | 12:06 AM
jg_98ghost's Avatar
ive got a 1200 watt Rockford amp. not very old. PM me if interested. i dunno what those speakers require but thats what i got.
Old Aug 12, 2007 | 11:33 AM
porksoda's Avatar
Some people in the audio forums I joined said this was a bad choice of subs because they are dual 2 ohm and amps are too hard to find for it. I don't know what dual 2 ohm means but is it true? Will I be better running 1 sub because I'd really like to put both in his truck.
Old Aug 12, 2007 | 04:58 PM
95bat's Avatar
You've got 2 subs, dual 2 ohm is perfect. The final ohm load will be 2 or 8 ohm, you want 2 ohm. Most amps won't run any lower than 2 ohm.
I'd run this.
