RCA need help fast
Old May 23, 2003 | 02:03 AM
sgalvin01's Avatar
Default RCA need help fast
Hey guys I have a question.. I bought an adjustable Line Output Converter today so that I can finally get some decent bass out of the TA.. Heres my question... It came with instructions that said " Gray wire(+) and gray/black wire (-) to the right speaker output of the source unit. Connect the white wire(+) and the white/black wire (-) to the left speaker output of the source unit" The unit has 2browns, a white, a white/black, a gray, and a gray/black wire coming out. DO I take the gray and connect it to the right (+) wire from the head unit in this case the Dark blue wire, and the gray/black to the (-) on the harness in this case the light blue? and same with the left side to the left rear outputs? AND should I use the rear speaker outputs, or the front? I know the two browns are grounds and do not have to be used..... All I need to do is cut the wire and connect both ends of the cut wire to the wire from the converter right?
My next question is about the adjustable part, how do you know if you need to adjust it, and what would adjusting do to it? I know these seem like newbie questions, but I have actually done car audio installs, just never with a converter.. thanks for your help!!!
Shawn
Old May 27, 2003 | 01:16 PM
TA TED's Avatar
STF Veteran
Default Re: RCA need help fast
Yes, wire it up like you stated and you could use front or rear, I would use the rear if you're using it for a sub so that you maintain your fader control. The adjuster is the gain pot. Basically a volume control that varies the line output voltage. Turn up your head unit until the factory speakers distort and then set the converter gain to make the subs sound max as well. Or basically just use the gain pot to match the amount of bass you want to the sound of the stock speakers.
