Firebird door panel removal
Old Sep 2, 2007 | 01:24 PM
flenser's Avatar
Default Firebird door panel removal
Hello,
This is the only firebird door panel removal howto I can find on the web. Does it look right? I am only trying to replace the door speakers so I really just need to know how to remove enough to get at the speakers. It looks like I need to go through steps 1 - 6, but if someone who has done this before could verify that these are the right steps, I'd appreciate it a lot.
http://www.lastofthebreed.com/Instal.../DoorPanel.htm
Thanks!
Old Sep 2, 2007 | 01:29 PM
02trns_am's Avatar
Yep those will work. The first time might be a little tricky. Just make sure you have all the screws out and that you take your time. Its really easy once you figure it out. Oh make sure not to break any of the little clips when your putting it back on. Don't force it to much it will just go when it goes. Good luck
Old Sep 2, 2007 | 03:09 PM
flenser's Avatar
Thanks for the confirmation. Of course, now I'm trying to figure out where to hide the crossovers since the ones I have are pretty big. I'm not sure they'll fit in the door and I only need them to drive the tweeters.
Old Sep 2, 2007 | 03:47 PM
WhiteBird00's Avatar
Ungrounded Moderator
You don't need an external crossover for the Trans Am's door components. There is an inline high pass filter in the factory wiring for the tweeters that will work fine for aftermarket tweeters.
Old Sep 3, 2007 | 02:39 AM
joblo1978's Avatar
I just did a window motor, there's plenty of room if you have to install one in the door.
Old Sep 4, 2007 | 12:41 AM
flenser's Avatar
Thanks. I thought the filter was attached to the tweeter itself like it is on the rear hatch tweeters.
