How do I remove my front door panel? (crank window)
Old Sep 4, 2007 | 03:33 PM
slaptastic's Avatar
Default How do I remove my front door panel? (crank window)
I've done it before on a 95 with power windows, but I can't get the crank for the window off so I can remove the door panel. How do I get the window crank off so I can get the panel off?
Old Sep 4, 2007 | 05:47 PM
KEE AUDIO's Avatar
Usually with crank windows you either have a removable panel on the window crank or in your case there is a weird shaped pin that is essentially a C-clip that is between the crank and the door that slides in from the side. They can be a pain to remove. I think there is a tool for this or before I could afford the right tools I used a carving fork like you'd use at Thanksgiving dinner to slide up in there and pop the clip out the other side. You'll have to locate the open end of the clip first so you make sure you are pushing the right way. The clips look like this, I know this is a different year but if it uses clips it will look soemthing like this:
http://cgi.ebay.com/ebaymotors/1978-...spagenameZWD1V
Old Sep 4, 2007 | 06:57 PM
camaro-94-z28's Avatar
the tool is 5 bucks at napa well worth it. just pay attention to where it flys (if it does) but get the tool it will save time then messing with a knife or fork.
Old Sep 4, 2007 | 08:02 PM
KEE AUDIO's Avatar
I agree!! I always buy the tool but I like to give people options..lol!! And it's that big 2 prong fork thing..lol...not the knife. This was about 15years ago for the record.
It does like to shoot off of there so watch it or have a friend around just in case!!
