Good Window motor??
Old Sep 5, 2007 | 06:47 PM
Mikey Crizzle's Avatar
Default Good Window motor??
I was wondering if anyone had bought window motors form ebay or advance auto parts. And if they were good or a peice of junk. Thankz, Mike
Old Sep 5, 2007 | 09:29 PM
SparkyJJO's Avatar
I bought mine from ebay, price was good and it work great so far. Aluminum housing and metal gear.
Old Sep 6, 2007 | 12:01 PM
todddchi's Avatar
I just did this and when I went to buy my motor, there were two different designs under the same part number. Both were made in South Korea.
The original / OEM style design is all steel. The newer design has a cast aluminum body shell combined with steel. I work in automotive supply and I can tell you, there are very few reasons to make an all new design in the aftermarket.
Logically, the new design must have been generated either due to poor quality of the old design (which we know) or for lower production costs. I do not feel the new design is cheaper. I actually think it would be more expensive to produce.
So my feeling is that you should try to find the cast body motors. It is a newer design and should be less vulnerable to moisture/corrosion wear.
Old Sep 6, 2007 | 01:13 PM
fastvert's Avatar
I bought mine on ebay and the seller actually had both the regular price motor($50 something), and the cheapy one($29.99) listed in his store and in the product description. He was outright in saying the 29.99 motor will not last as long, and should be considered a short term fix. He mentioned that he carried both designs because some people purchased the cheaper one and were fine with it for years, yet some reported that they didnt last long at all and had to be replaced once again.
IF you have ever done a replacement before you know its a pain, and i certainly wouldn't wanna do it over again any time soon. Id say spring for the one thats a little more expensive and do it right the first time. Better yet, buy the windowfix from autotrix (sponsor) and do it the same time you replace your motor, and youll be happy for a long time. It will extend the life of your new motor with better voltage coming directly from the battery.
Old Sep 9, 2007 | 04:00 PM
99DWPTA's Avatar
advanced auto 1 year so far
