Whats needed when upgrading to a HO alternator?
Like I said, different cars have different setups and requirments. I found what I needed thanks to this thread, and will be buying one VERY soon.
yea, i searched and searched but came up with nothing. glad the thread helped out some people other than myself!
and $300 for an alternator is expensive, but its one of those things that needs to be upgraded. plus it came with a 2yr warranty!
The stocker just needs to go. After I did my battery re-location, and installed 1: Rockford 1000bd and 2: 400-4 amps it is really suffering.
i think you just wasted your time with your post...
but anyways.... my car is far from stock. with my cam, the car idles at 800-900 rpms, not 500. plus i have lots more things to power at WOT, so this alternator will work just fine for me.
If you search that same guy's buy it now listings, he has teh same exact alternator listed at 275 in some listings and 250 in others.
whats the deal with that? after i did my cam swap my voltage sucks. i mean i know the car idles around 750 but even under throttle it still is barely at 13v with the stereo off. Thats even using a red top optima!
A real alternator will put out decent output at idle as well as full output uunder 2k rpm.
I tested my alternator (200A Excessive Amperage) with an amp meter when I got it. It put out 110 amps at idle, which is about 900rpm in my car. That was actually the most power my stereo could draw, too, so who knows if it can put out more.
As I said before, I think buying an alternator that can't put out decent voltage at idle is a waste of money. 45 amps at idle is no better than stock.
Do the math smart guy, if it makes 146.8 at 833 rpm and 189.1 at 1000 rpm, then you take into account the diminishing increase in amperage as rpms increase you will come up with approx 166.x amps at 900 rpm. Even if you suck at math it doesn't take a smart fella to know that at 900rpm it will be greater output than at 833rpm. If you use a different math approach, you come up with 157 amps at 900 rpm. Either way, I'm right and I don't understand how you don't comprehend the facts here. Thanks you, come again.
http://cgi.ebay.com/ebaymotors/ws/eB...099219015&rd=1
well i was gonna respond, buy you summed it all up for me... thanks you jesus!!
