New Head Unit from Monsoon
I put an Alpine CDA-9885 in my car with the stock Monsoon amp/speakers and it was definitely an increase in sound quality over the stock head unit. Didn't have to do anything special. Bought the Humount plate kit and a cheap $7 wiring harness from Walmart. Sounded better than the Blaupunkts I replaced the stock speakers/amp with. Still need to put an amp on these things and see if they sound better.
There is an adapter harness for about $10 that will save you from cutting the connector off of the factory harness. You splice it to your aftermarket radio wiring and then it just plugs into the factory harness. It's the same adapter harness that's been used on GM products since the mid-80s and it's available at any audio shop and even WalMart.
