ne one know how disable sensor for headlights?
Old Jun 5, 2003 | 06:09 PM
wickdss's Avatar
Default ne one know how disable sensor for headlights?
I was just wondering if there was a way to turn the headlight on from the switch only? Not having them go on automatically when you turn the car on.
Old Jun 5, 2003 | 06:26 PM
project9sec's Avatar
Default Re: ne one know how disable sensor for headlights?
i know there is a wire on the e-brake that when the e-brake is completely released that is when the headlights go on i would play with that im not sure i think it is the same wire as the one that tells you your ebrake is on
Old Jun 5, 2003 | 07:12 PM
Z_Man's Avatar
https://ls1tech.com/threads/showflat...14&fpart=1
If you disable the DRL module you will lose other things like the BRAKE light...its the light sensor you wanna play with.
