Watts a good wattage?
I think I recall someone saying that the stock speakers in the trans am is only like 20 or 50 watts of RMS power. is this true?
I want to chance the stock speakers, but dont want to spend a lot of money. Whats a good RMS level to shop around in? I like my music fairly loud but not deaphening. I listen to hip hop, rap, some rock, and some country.
any help?
For the amp, the more the better because it means you don't have to push the amp as hard. The lower the gane setting is on the amp, the clearer the sound will be. 50 watts per channel is typically good if not overkill for most people while I would say 20 is on the low end. If you get "too much," just turn the gane (sp?) down on the amp.
For speakers, if your running them off the factory amp, you need something that had a high sensitivity factory. This way they will be able to play loud on the low amount of power that the factory amp puts out. If your running them off an aftermarket amp, this is not that big of a factor as you have more power to work with.
Really I would say if you have not done it yet, change the amp, not the speakers. The factory speakers (like many crappy speakers...) can take a lot of power. Its distortion that kills them (not to mention sounds bad). By having a good sized amp, you will lower the distortion level and be able to run them louder.
Chris
Russ
