steering wheel control not lighting up
Old Oct 4, 2007 | 06:31 PM
3800RS's Avatar
Default steering wheel control not lighting up
On the trans am the steering wheel controls were fine about a week ago. tonight i notice none light up at all. i doubt all the bulbs went out at once, they still function. Anyone know what it can be. i checked that little 1 amp fuse, visually it looked fine but i plan on replacing it also to know for sure. Thanks
Old Oct 4, 2007 | 07:12 PM
WhiteBird00's Avatar
Ungrounded Moderator
There are two 1-amp fuses for the steering wheel controls. One is for the actual switch function (#3) and the other is for the illumination (#13). As you mentioned, always test a fuse or replace with a known good fuse because they can look fine even when blown.
Old Oct 4, 2007 | 08:47 PM
3800RS's Avatar
i will have to check out fuse 13, i only looked at fuse 1. thanks for the info whitebird. when it comes to electronice you're the man !!!
