12Volt hardwire question...I need help
I have all the wires run where I want them. I ran them down under the steering column cause I heard there was an easily accessible ground screw down there. I found the ground screw, and now I am trying to figure out which of these 10,000 other wires would be a 12V power wire.
Are all the wires except the grounds 12 volts? How do I figure out which wire to tap into? Does anyone know of a specific wire that I can tap into under there? I need help ASAP because the interior is all apart and I want to drive my car tonight.
PLEASE Help if you can.
Thanks in advance.
Paul
thanks -matt
The wire I tapped into was a thick red wire. It was visible in the opening that is behind the hatch release button under the headlight ****. There is also a ground screw in the opening under the steering column. The thick red wire looked to me to go to the fuse in the fuse box that read "12V 30amp" That's why I tryed it, and whala, it worked. I guess I got lucky. I ran the straight cord (as opposed to the coiled one) up through the A-pillar and under the roof carpeting to where the rearview mirror wire come out. The only thing you see is the wire coming out and connecting to the V1. Looks very stealth, and only took about an hour start to finish.
If you get the V1, good luck with it all.
You should have a pink wire coming off the ignition harness that is key-on 12v, as well as a yellow wire off the radio harness.
