to cap or not to cap..that is the question
Old Oct 15, 2007 | 01:07 PM
HIZPANICGUY21's Avatar
Default to cap or not to cap..that is the question
just like the title says above. i have a pioneer double din h/u, jl 500/1 amp, and 2 jl10w3v3-4 (300 rms each), and rear enclosure subthump box..i was told that i would be fine and not need a capacitor. but ive noticed that when i really turn it up the lights and speedo lights dim to the bass. i just purchased a power acoustik 2 farad capacitor (got a great deal on it) would running only 500 watts of bass require me to use a capacitor? or could it be something else that causes my lights to dim to the bass.hmmmm,
also, beneath is a real quick drawing of how i think the cap should be hooked up.i believe it goes like this,
1-power from battery to cap then to amp. ground from amp to cap
2- OR power from battery to cap then to amp, ground from amp to chassis
Old Oct 15, 2007 | 01:15 PM
98Ws698's Avatar
Caps are not the answer to any problem. You're best bet would be to try an dfit either a larger than stock battery under your hood, or add one to the back.
Upgrading the Big 3 while you're under the hood will also aid in electrical issues.
Old Oct 15, 2007 | 01:20 PM
elaborate on all of this please..what do you mean BIG 3
Old Oct 15, 2007 | 01:39 PM
dragonrage's Avatar
A battery is not an option, either.
Upgrade your power and ground cables under the hood (that is commonly called the "big 3"). If that doesn't work, alternator.
Old Oct 15, 2007 | 02:32 PM
ultraz's Avatar
a cap will help your situation, but far from fix it. The problem you are explaining is that your car accessories and stereo are draining the battery faster than its being replenished by the alternator. Hence, your stereo drains your battery and starts taking what it needs directly from the alternator, not allowing your battery to charge like it should. The only real remedy is an alternator with higher than factory amperage in order to fullfill the needs of all the accessories in your car.
Old Oct 15, 2007 | 02:34 PM
pentavolvo's Avatar
Big 3 is what you need, not a cap
Alternator + to battery +
Battery ground to block ground
Battery ground to frame ground or frame ground to block ground
Old Oct 15, 2007 | 03:09 PM
Gordon0652's Avatar
I went from the stock battery to a Red Top, and it made a huge diffrence! Look at my sig to see what i am running.
Cap:
$99.99
Doesnt do much or anything at all.
Looks cool.
Red Top
$159.99
Makes an over all difference in all electronic parts.
Is Cool.
Old Oct 15, 2007 | 03:36 PM
dragonrage's Avatar
Wrong way to do it. Your audio system should not need your battery at ALL unless your car isn't running.
Old Oct 15, 2007 | 03:41 PM
Gordon0652's Avatar
My lights dimmed and everything, and ever since i bought the battery they havent.
Old Oct 15, 2007 | 05:02 PM
Websy21's Avatar
screw the cap, got one back in the day when I was a young lad and that was the last one I ever used with atleast 6 different setups in different vehicles since
Old Oct 15, 2007 | 06:04 PM
95bat's Avatar
Agreed with the others, caps are a pure marketing fluke. They do nothing to help a stereo.
Old Oct 15, 2007 | 07:48 PM
98Ws698's Avatar
Extra Batteries FTMFW...
2 of my 6 pictured there.
Dragonrage, you realize how much current an amp draws right? How do you expect it to get that without using the battery?
Old Oct 15, 2007 | 11:24 PM
habeba86's Avatar
Mags? Kinetik f-t-w!!
Old Oct 15, 2007 | 11:51 PM
98Ws698's Avatar
6 SSD 10s
Old Oct 16, 2007 | 12:11 AM
habeba86's Avatar
I was thinkin about doin 2 Q's in the t/a...... How do you like them....what is the box specs?
Old Oct 16, 2007 | 07:13 AM
dragonrage's Avatar
If you can get a 240A alternator, you'd be hard-pressed to find an amp that needs to use the battery. Maybe if you were sitting at idle it would use the battery a bit, but otherwise....
Old Oct 16, 2007 | 03:31 PM
98Ws698's Avatar
i guess my daily driver having 4 autotek mm4000s and 10 batteries changes my opinion right?
Old Oct 16, 2007 | 03:32 PM
98Ws698's Avatar
I loved them. The box was 9.2 cubes net with 120 sq. in. of port and tuned to 33 hz. I could burp a 148.9 with 4 and 5kw at 35 hz.
dragonrage's Avatar
All I have to say is... why?
Old Oct 16, 2007 | 03:46 PM
98Ws698's Avatar
I compete in DB Drag
