Amp Elemental eu700's, or put in 10" sub?
Old Nov 2, 2007 | 01:06 AM
DUhulk78's Avatar
Default Amp Elemental eu700's, or put in 10" sub?
Hey guys. I'm just wondering on this. I put some elemental eu700's in the sail panels of my 00 camaro SS. They sound good, but i'm wondering.. should i get a 250x2 amp for them, or just get a few tens to put in? Which would have a better effect? I already have 2 tens and an amp from a previous vehicle, but i don't have a box for them yet. Which would have more effect? Thanks!
Old Nov 2, 2007 | 09:09 AM
95bat's Avatar
Box would the cheapest option if you make it yourself. The 10s will also give you more bass than the eu700s. Those eu700s definately deserve an amp though
I think you'll be happy either way. Put the amp for your 10s in those eu700s and see if you like it.
Old Nov 6, 2007 | 11:16 PM
DUhulk78's Avatar
I would but my amp puts out 400x2 rms. It's a lanzar, which isn't the absolute best, but it's done great things for me so far. U think i could hook it up to my elementals, and just keep the gain turned down?
Old Nov 7, 2007 | 08:55 AM
95bat's Avatar
Yup, it would work just fine
Old Nov 7, 2007 | 09:11 AM
KEE AUDIO's Avatar
You can do that but most use the eD's because they are one of the only dual voice coil 6.5" subs on the market. This is usually a concern for the trans am/firebird with the Monsoon because it's the only sub that is wired exactly like stock. You have a Camaro which is not wired like the firebird it uses a single voice coil 2ohm sub, plus your planning on aftermarket power to them so this opens up a whole realm of sail panel options other than the eD. Just thought I'd point that out as there are other options that don't require a spacer.
Old Nov 7, 2007 | 12:53 PM
DUhulk78's Avatar
I already have the eu700's installed in the sail panels, with spacers, and i sprayed truck bedliner all around the area.
Old Nov 8, 2007 | 08:50 PM
01ssreda4's Avatar
go for the 2 10s man, hell you already got em.....
