changing battery out
Old Nov 19, 2007 | 02:31 AM
30thanniv's Avatar
Default changing battery out
If I disconnect my battery to install a new one,will my radio security lock?
I do not have the security code to unlock it.
I was thinking that if it does lock if disconnected that I could keep the car juiced with my battery charger, while I swap the new battery in.
Ideas? comments?
Old Nov 19, 2007 | 07:59 AM
WhiteBird00's Avatar
Ungrounded Moderator
Our cars came from the factory without the radio TheftLock enabled and most owners never bothered to input a locking code to enable it. If the little red LED on the radio face doesn't blink when you shut off the car then the TheftLock isn't enabled and you can disconnect the battery without worrying about it locking. Even if it is enabled and you don't know the code, you can still reset it using the instructions in the Monsoon FAQ sticky.
